USG Limitation of DHCP6 DUID of 41 characters! - any clues?
warwickt
warwickt Posts: 111 image  Ally Member
5 Answers First Comment Friend Collector Third Anniversary
edited April 2021 in Security
Hi USG-philes and Zyxel-lads...., can't configure Ubuntu18 Desktop IPV6 DHCP6 DUID longer than 41 characters into USG60/40 at firmware V4.32( 2018) .
Using STATEFUL DHCP with DHCP renovations to service DNS.....
 -------> Configuration / Objects / DHCP6 / Lease / Add / Add Corresponding / Lease Type / Prefix Delegation / DUID .
In the example below the dhcp6.client-id is  an expanded string of
x'00:ee:39:51:46:22:74:01:21:19:f1:ad:ac:f2:ac:0d:02:26'
Refer Ubuntu18 Desktop example....:
 /var/lib/NetworkManager/dhclient6-7??????f-4ba0-3b3d-????-33020?????33-enp3s0f0.lease
default-duid "\000\xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx\231&";
lease6 {
  interface "enp3s0f0";
  ia-na a3:07:09:41 {
    starts 1533638143;
    renew 4294967295;
    rebind 4294967295;
    iaaddr 2001:xxx:xxx:xxxx::99:8 {
      starts 1533638143;
      preferred-life 4294967295;
      max-life 4294967295;
  option dhcp6.client-id 0:ee:39:51:46:22:74:1:21:19:f1:ad:ac:f2:ac:d:2:26;
  option dhcp6.server-id 0:4:0:6:70:99:96:21:7ee:ac;
lease6 {…..
There is a limit of 41 characters in the above field.
Yes can workaround this , however this limitation is possible coding laziness at the s/w end in 台湾   :3
Any Clues?
posted to USG Security forum this time.
B/R
Warwick
Hong Kong
