Custom Web Portal issue
i use a corporate design for guest login via custom web portal.
after enter login credentials, page style switches to default style with text "you are logged in" . same happend if wrong login credetials is used.
How can i change the login dialogue completly?
Hi @MirkoW
After customizing the captive portal, did you add a policy rule for it?
Add your customize captive portal in "Custom Captive Portal"
Then, go to the "Redirect on Controller" and add a policy rule. Choose the "Portal Theme" as you customized in "Custom Captive Portal".
Please let me know if it helps.
Thanks.
Joslyn0 -
i use a UAG2100.
Some design settings are under System > WWW. There i can't use a corporate design. Only text and colors are possible to change.
Regards, Mirko
Hi @MirkoW
Since this discussion topic is related UAG series, here is WLAN enterprise products area.
I will help to move this to the UAG series. We will have another team member to reply your question.
Thanks.
Joslyn0 -
Hi @MirkoW
If you would like to change the Web Portal, you can go to Configuration > Web Authentication function to change Web Portal as you wish.
1. In Custom Web Portal File, there is a default Web portal file. You can download the default web portal, and modify xxx.html file, and then upload to UAG again.
2. Create a Authentication Type for customized web portal
3. Apply the Authentication type to web authentication rule.
Hello Stanley,
this is what i try, but after logging in or using wrong credentials, i get another page with default style.
This sites can be modified under System > WWW > Login page tab
(i use the german interface so i'm not sure if it is the correct name)
It is not able to use own style for this pages.0 -
Hi MirlkoW
The customize page is only displaying when your page is redirected to login page.
If you enter IP of UAG, it will only shows default login page.
e.g. When user is connect to UAG and not authentication yet. (WebAuthentication is enabled)
And accessing to http://www.pchome.com.tw, it will redirect to customize page.
windows 10 opens Edge and showing login site automatically after access to wlan. After logging in, results will shown in default style.
Now i use the default style with own logo and color styles.
This ticket can be close.0
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
