New Small Business Access Point - NWA50AX and NWA55AXE has been released!
Zyxel_Bella
New
WLAN Access point is supported. A brand new small business AP, NWA50AX and NWA55AXE, is
on-boarding to Nebula platform in this release. Small Business Access Point comes with right-fit
feature set and simplest configuration make it the best choice for
small-business. Following table is the supported feature matrix and limitation while operate on Nebula control center.
Note: The features not be listed in the table are not supported and shall not be applicable.
I'm currently running custom firmware datacode: "V6.25(ABZL.8)-DF-2022-05-09" for my NWA55AXE because of a bug.
When will this fix be integrated in the next "real" official firmware update?
Best regards
Floris0 -
Great, thanks for the info.
Regards
Floris1 -
I see firmware "6.25(ABZL.10)C0" is released.
Can you tell me if the fix from "datacode: "V6.25(ABZL.8)-DF-2022-05-09" is included in this release?
Regards
Floris0
- 431 Beta Program
- 2.6K Nebula
- 165 Nebula Ideas
- 6K Security
- 364 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 262 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
