Geo IP Database Errors
LosHighander
When I try to add (or remove and re-add) GEOs, I am returned the below error:
CLI Number: 0
CLI Number: 0
Warning Number: 124003
Warning Message: 'Geo IP database of this country is empty.'
Does anyone have any idea on how to resolve? All the firewall rules that were using a filter of only accepting traffic from the US Geo started failing. When I switched the source to any, things would work. Went to remove and re-add the US Geo and came across the issue. Looks to affect all GEOs.
I manage several offices with the same model USG (all running same version firmware and related). Only this office is having the issue.
Which country name that you selected in object?
And you may update GeoIP data base and try it again.
(Configuration > Object > Address/GeoIP > GeoIP > click update now button.)
When trying to add any country, that is the error returned. The GeoIP database is running the newest version (20180809).0
I will send you private message for check this issue more detail.
Hi,I have the same problem, how did you solve it?I noticed the problem after updating the firmware to the last version 4.32 on USG110
Returning to 4.31, however, the defect remains.
Hi @LosHighander and @Alex_91
The issue has fixed on your device. And it will fixed in next firmware release.
- 603 USG FLEX H Series
- 481 News and Release
