Is there any EOL schedule for zywall usg series?
Hello, which we recommend to replace USG110 ?Will continue for USG110 AV, IDP + GeoIP updates ?Very thanks for answer
Hello it will be interesting to have an EOL matrix for USG Hardeare also.
Grazie
Maurizio
Which firewall model is the most popular and the most used one?0
Hi @Momo
The EOL devices list(End of Life)is in "Support" category of Zyxel home page bottom.
End of service is at 24 May 2022.
End of RMA & Tech Support is at 16 May 2024.
@Carlos8
USG FLEX series and ATP series firewall are the newest firewall products.
We offered different hardware level for different network scope. (SMB recommend to use 200 or 500)
FLEX and ATP series are offering different security services. You can compare them by license & Spec page for FLEX500 and ATP500.
Zyxel_Stanley
Grazie for the infos... Until now I have only found the EOL list for licences...
I checked en See the EOL for HW.Nice day to both two
M.0 -
thank you for the link to the EOL page.
when was the EOL date defined for the USG series? as I understand it, this date was defined right now? this forum post is from april 2021 and only now a date is mentioned.
a manufacturer must announce the EOL date in advance so that customers can plan and budget for replacements.
is there already an EOL date for the ATP and Flex generation?
Thank you for your quick reply but I don't want the newest.Which one is the most used one ?0
well I hope I get my
session-status-update zyfilter inactive
in for the USG/Zywall seeing that they are EOL1
- 441 Beta Program
- 534 USG FLEX H Series
- 334 Security Ideas
- 51 Wireless Ideas
- 293 Service & License
- 461 News and Release
