New Firmware USG Flex
Message from Zyxel:
Dear user, Please apply the patch firmware ZLD V5.30 for your security appliances, it can effectively defend against the threat. Zyxel has released a new firmware ZLD V5.30 to patch the latest vulnerability CVE-2022-30525. Your help is crucial to containing this threat. Review the security advisory immediately to prevent your network from the exploit.
If i go to my USG this appears:
Eine neue Firmware ist für ein Upgrade verfügbar. Möchten Sie nun upgraden?
If i go to yes, install, this happens:
Please note that your new firmware download feature is disabled due to ITS installed. Please contact local support to ensure the upgrade is applicable.
So the ol' firmware is : V5.10(ABUH.0)ITS-WK42-2022-01-03-211200894
special one cause USG didn't work properly.
So if i install the new one ( as Zyxel recommends) manually, does my USG still work or will i have the same problems like before?
Yes install 5.30 manually it should work.0
- 220 Nebula Ideas
- 603 USG FLEX H Series
- 482 News and Release
