ATP 500 client can not connect to FTP
JFDATA
JFDATA Posts: 2 image  Freshman Member
Hello
We have a strange problem. It is not possible to connect to a FTP server from LAN to WAN. I have turned of all security services and added IP exceptions. But still no luck.
If we attach our old USG 200 then no problem???
/Peter
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,368 image  Zyxel Employee
    100 Answers 500 Comments Friend Collector Fifth Anniversary
    Hi @JFDATA
    Welcome to Zyxel community :) .
    Can you enable FTP ALG feature on your device and make sure the FTP port(the default value is 21) is correct? You can check it on the Web-GUI path Configuration->ALG-> FTP Settings, as the below screenshot:
  • Zyxel_Jeff
    Hi @JFDATA
  • JFDATA
    Hello Jeff
    Thank you that did it.
    /Peter
