Is there any EOL schedule for zywall usg series?
  • kyssling
    kyssling Posts: 107 image  Ally Member
    First Comment First Answer Friend Collector Sixth Anniversary
    Hello, which we recommend to replace  USG110 ?
    Will continue for USG110 AV, IDP + GeoIP updates ?
    Very thanks for answer
  • Zyxel_Can
    Zyxel_Can Posts: 342 image  Zyxel Employee
    25 Answers First Comment Friend Collector
    Hi @kyssling,
    USG110 will still get AV, IDP and GeoIP updates.
    However USG FLEX and ATP series offers more advance protection. We recommend you to use USG FLEX or ATP series.
    Best regards.
  • Momo
    Momo Posts: 14 image  Freshman Member
    Hello it will be interesting to have an EOL matrix for USG Hardeare also.
    Grazie
    Maurizio
  • Carlos8
    Carlos8 Posts: 4
    Friend Collector
    Which firewall model is the most popular and the most used one?
  • Momo
    Personally I used Zywall 20w and the 40w but not both are quite out EOL (EOS).
    My question was about the official support state but not easy to find
  • Zyxel_Stanley
    Zyxel_Stanley Posts: 1,398 image  Guru Member
    Hi @Momo
    The EOL devices list(End of Life)is in "Support" category of Zyxel home page bottom.
    End of service is at 24 May 2022.
    End of RMA & Tech Support is at 16 May 2024.
    @Carlos8
    USG FLEX series and ATP series firewall are the newest firewall products.
    We offered different hardware level for different network scope. (SMB recommend to use 200 or 500)
    FLEX and ATP series are offering different security services. You can compare them by license & Spec page for FLEX500 and ATP500:)
  • Momo
    Zyxel_Stanley
    Grazie for the infos... Until now I have only found the EOL list for licences...
    I checked en See the EOL for HW.
    Nice day to both two :)
    M.
  • Mario
    Mario Posts: 109 image  Ally Member
    Zyxel Certified Network Engineer Level 1 - Security First Comment Friend Collector Sixth Anniversary
    thank you for the link to the EOL page.
    when was the EOL date defined for the USG series? as I understand it, this date was defined right now? this forum post is from april 2021 and only now a date is mentioned.
    a manufacturer must announce the EOL date in advance so that customers can plan and budget for replacements.
    is there already an EOL date for the ATP and Flex generation?
  • Carlos8
    Carlos8 Posts: 4
    Friend Collector
    Thank you for your quick reply but I don't want the newest.
    Which one is the most used one ?
    PeterUK Posts: 4,121 image  Guru Member
    well I hope I get my
    session-status-update zyfilter inactive
    in for the USG/Zywall seeing that they are EOL
