LTE3311-Q222 - failover or choose source?
jan_k
I have two source of internet - my ISP with ethernet cable and LTE sim card.
Can I connect simultaneously both to LTE3311 and set primary source as ethernet and backup as LTE (failover)?
Or maybe create two SSID - one with source from sim card, second from ethernet?
Best regards,
Jan
Best regards,
Jan
Hi @jan_k Jan,
I think that you only need to set up 1 SSID for WiFi, which can use both your ISP Internet connections, primary Ethernet and backup LTE.
I think that that the LTE3311-Q222 will be able to route your outbound traffic to whichever is active and should be able to prefer the Ethernet.
Kind regards Tony0
- 234 Nebula Ideas
- 6.7K Security
- 695 USG FLEX H Series
- 366 Security Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 312 Service & License
- 510 News and Release
- 97 Security Advisories
- 5.1K FAQ
- 89 About Community
- 114 Security Highlight
