SSLVPN disconnects and oddness with zone “LAN”
2»
    PeterUK Posts: 4,446 image  Guru Member
    Just worked out whats causing the oddness with zones it seems SSL VPN port 443 links to “WWW” for “User Service Control” which I had limited to LAN1 what odd is this only applies to "WWW" and SSL VPN on port 443 if you change the SSL VPN port then “User Service Control” does not apply.
  • Zyxel_Kevin
    Zyxel_Kevin Posts: 981 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate 100 Answers 500 Comments
    Hi @PeterUK
    We're investigating the issue. Will feedback to you if any result.
    Thank you
    Kevin
    My guess is the “User Service Control” when SSLVPN is port 443 with WWW is doing what it should and that by changing the SSLVPN port you loss that control and its just all zones.
  • Zyxel_Kevin
    edited June 2022
    Hi @PeterUK,
    Once SSLPort doesn't match WWW service port.The SSLVPN access will not be restriced by ACL.
    This is the new enhancement.
    Thank you
    Kevin
