Switch GS2210 Series - V4.50 Patch 2 Firmware Release
Zyxel Switch GS2210 Series
Release Note
December, 2020
Firmware Version on all models
(Click Hyper link to download the firmware directly)
Zyxel GS2210-8 - V4.50(AASP.2)
Zyxel GS2210-8HP - V4.50(AASQ.2)
Zyxel GS2210-24 - V4.50(AAND.2)
Zyxel GS2210-24HP - V4.50(AANE.2)
Zyxel GS2210-24LP - V4.50(ABEO.2)
Zyxel GS2210-48 - V4.50(AAHV.2)
Zyxel GS2210-48HP - V4.50(AAHW.2)
New Feature and Enhancements
No. |
New Feature and Enhancements |
CLD |
STK |
STD |
1. |
VLAN mapping |
V |
2. |
DHCP Auto configuration |
V |
3. |
CLV Command |
V |
4. |
NTP Server supports DNS format |
V |
5. |
Enhanced dual image resilience |
V |
6. |
SHA2 |
V |
7. |
Loop guard enhancement |
V |
8. |
Show IPv6 socket |
V |
9. |
Logout all current user access after changing the device management IP |
V |
10. |
Display port utilization |
V |
11. |
Use [Ctrl+C] to escape when executing “show running config, show log” |
V |
12. |
Time sync (NTP) over IPv6 |
V |
13. |
Cable diagnostic MIB |
V |
14. |
Syslog setup for IPv6 and UDP port |
V |
15. |
ZDP v1.8.3 |
V |
16. |
Time stamp for save configuration |
V |
17. |
POE default mode change to consumption mode, and the default config will show consumption mode setting.(POE model only) |
V |
18. |
Web login warning page |
V |
19. |
802.1x EAPOL flooding |
V |
20. |
IGMP snooping leave-proxy |
V |
21. |
Custom Default configuration |
V |
22. |
Smart fan (designed to automatically adjust speed based on device temperature) |
V |
23. |
Improve the bandwidth control accuracy under lower rate, especially for ISP application |
V |
24. |
Enhanced GUI with new Zyxel logo |
V |
25. |
Avoid multicast group cannot be added while mac collision happens |
V |
Bug fix
No. |
Bug fix |
CLD |
STK |
STD |
1. |
[eITS#151100702] When switch enable ARP inspection and DHCP snooping, it will cause DHCP packets be flooded to other ports. |
V |
2. |
[eITS#151200455/ 170200710] particular Cisco IP phone may release IP (DHCP mode) after every 180 seconds. |
V |
3. |
[eITS#151201303] SNMP GETBULK produces incorrect results when max-repetition is set greater than 55. |
V |
4. |
[eITS#160101145] The switch cannot flood the EAPOL packets when 802.1x is disabled. |
V |
5. |
[eITS#160200247] Displayed port speed value is triple the actual speed for both TX and RX. |
V |
6. |
[eITS#160300698] Partial configuration loss occurs after configuring private VLAN via web GUI and rebooting switch. |
V |
7. |
[eITS#160501171] Switch cannot forward IGMP query when using MSTP. |
V |
8. |
[eITS#161000919] Web GUI session does not timeout properly if user does not close the browser. |
V |
9. |
[eITS#170100698] The switch cannot auto adjust RSTP path cost according to the port speed. |
V |
10. |
[eITS#170300428] Switch has high ping latency periodically due to the routine runtime task. |
V |
11. |
[eITS#170400423] No longer boot up after firmware uploaded. (Only for GS2210-24LP) |
V |
12. |
[eITS#170500473] Prevent unexpected reboot caused by Avast antivirus software. |
V |
13. |
[eITS#170500522] The switch may reboot unexpectedly after changing the current settings of classifiers. |
V |
14. |
[eITS#170500863] Switch may encounter unexpectedly reboot under a large IP network environment. |
V |
15. |
[eITS#170600557] Floods an IGMP query every time when switch receives an IGMP Leave. |
V |
16. |
[eITS#170801018] Sometimes SNMP agent returns incorrect gateway MAC address. |
V |
17. |
[eITS#170900439] Switch does not provide PoE power when the time range is very closed to NTP synctime. |
V |
18. |
[eITS#171000095] The SNMP ifHCInOctets/IfHCOutOctets(counter 64) cannot count exceed 2^32. |
V |
19. |
[eITS#171000116] Operator cannot modify the syslog server level via SNMP while Syslog server is activated. |
V |
20. |
[eITS#171200272] Client traffic is unexpectedly discarded after MAC address aging time when IPSG and port security are enabled. |
V |
21. |
[eITS#180100999] Switch may miss configuration if upgrades to new firmware. |
V |
22. |
[eITS#180200048] Web GUI may display Syntax error when restoring configuration. |
V |
23. |
Enhance the UX with MacBook by changing the ASCII of the backspace to follow the industrial standard. |
V |
24. |
Switch can’t be managed via WEB/CLI smoothly when there are a lot of broadcast/multicast traffics in the network environment. |
V |
Please refer to the Download Link for more details.
Adam
This link does not work anymore. Why would ever somebody do that?
please provide the link for the GS-2210 series. Thank you.
we can't recover lsot password without those roms...0 -
Hi @Mike_Mike,
The "Download link" is to redirect user to a GS2210 release note.
If you would like to download the .rom file, please download the file on the top of this page.
Thanks,
Zyxel Nebula Support
- 238 Nebula Ideas
- 6.8K Security
- 748 USG FLEX H Series
- 377 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 320 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
