LAG rate limit
PeterUK
PeterUK Posts: 4,446 image  Guru Member
edited May 2022 in Security
VPN300 V5.30(ABFC.0)
I have setup a LAG bridge between LAG0 and LAG1 because I can and on LAG1 I limit egress to 92160Kbps and this works fine just so you know, but this is the bit I don't get you normally LAG two or more ports to get more speed (if say your ISP gives you 1.5Gb) but you can't seem to set the LAG speed limits higher then 1048576Kbps so you will never go faster than 1Gb no matter how many ports you LAG? So shouldn't the LAG take the number of ports say two and set the limit upto 2097152Kbps.
  • MJStar
    MJStar Posts: 37 image  Freshman Member
    First Answer First Comment Friend Collector Fourth Anniversary
    It seems a current limitation for this scenario. The bandwidth won't be increased.
  • dkyeager
    dkyeager Posts: 71 image  Ally Member
    edited June 2022
    This also seems to apply to USG Flex 500 5.3 firmware, however it can also be set to 0, which may be a workaround to possibly allow higher speeds.
    Nope 0 really means 0 just tested if you really need to limit at 1.2Gb say then the LAG needs to add up the ports to a new total limit any one port will still be limited to 1048576Kbps.
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,368 image  Zyxel Employee
    100 Answers 500 Comments Friend Collector Fifth Anniversary
    edited June 2022
    Hi @PeterUK
    Thanks for your feedback.
    The below is our description of User guide.
    It’s a current insufficient design on the LAG interface egress bandwidth setting, we will evaluate how this part can be improved in the future.
  • mMontana
    mMontana Posts: 1,468 image  Guru Member
    OUCH...
    So the only use for LAG is redundancy.
  • Zyxel_Vic
    Zyxel_Vic Posts: 323 image  Zyxel Employee
    25 Answers First Comment Friend Collector Eighth Anniversary
    Hi @PeterUK
    Well...not only for redundancy but also the aggregated tput will still be larger than 1 port.  Thanks for your feedback about this.
    edited June 2022
    No it will still be 1048576Kbps (1Gb) traffic will not go faster then that out of any one port.
    Say the LAG hashs two sets of traffic that can go at say 700Mb each out of each port of the lag that can't happen the best that can happen is 500Mb (less with overhead) out each port because the LAG limit is 1048576Kbps (1Gb).
