Set DHCP Lease To One Day
businessuer
businessuer Posts: 134 image  Ally Member
Let say person logs in 1 jan at 08:00 hrs and logs out at 1 Jan 17:00 hours.
DHCP Lease set to 2 days.
So will the lease expire at 3 Jan 08:00hrs or 17:00 hrs?
Will setting a lease duration of 1 day be too short because the router have to keep "re-learning" mac addresses?
Will it affect the hardware?
  • mMontana
    mMontana Posts: 1,443 image  Guru Member
    Both questions: IMO no.
    In a low-ratio hardware rotation environment (resident people only, two - to five missing person par day on 50-60 persons) having multiple-day lease won't be an issue. If a device come back at the last hours of lease, it will receive the same address.
    In a hi-ratio hardware rotation (bar, restaurant, commercial space, hotel) shorter the lease time, less wasted addresses waiting to expire.
    I choose a /23 subnet for the guests wireless network into an hotel with 60 rooms, considering three devices par room plus 180 devices for congress/dining halls (twice the size of the maximum capacity. Lease time 4 hrs.
    PeterUK Posts: 4,264 image  Guru Member
    edited June 2022
    You can set the Lease time to 2 minutes and it be fine.
    The client can ask for a renew by DHCP by unicast before the lease time and before the client renews by broadcast which reset the lease time.
  • businessuer
    Sorry but why is a broadcast necessary?
    edited June 2022
    Well you need a broadcast to get a IP but if you mean for renewing a IP the client may not send a unicast request and waits till rebinding which is a broadcast and it can ask for a reply from the server to be a broadcast or unicast.
    More about DHCP here:
    https://lazyadmin.nl/home-network/dhcp-lease-time/
  • mMontana
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,244 image  Zyxel Employee
    Hi @businessuer,
    Just like @PeterUK's explaination and @mMontana's suggestion, you can depend on your envirement to set suitable lease time, DHCP Server pool and subnet.
    Zyxel Melen
Nebula Tips & Tricks
