Usg210 ike v2 vpn connection with samsung s22
Hi
The new android phone support only ike v2 VPN.
I try config vpn server role, but not work...
I try with certificate and with only password...but i have a problem to connect.
I install StrongSwan app...but i have same problem.
Have you a tutorial for vpn ike v2 for android phone?
Manuel
Manuel
You need Phase 1 and 2 with the right encryption
VPN Server role IKEv2 broken as far as I can tell — Zyxel Community
Phase 1 on some phones needs a higher Key group
Hi @Manuel13
If you have USG Flex or ATP models you can refer to this tutorial :
Remote Access VPN Wizard for SecuExtender IPSec and Non-SecuExtender IPSec VPN Clients
https://community.zyxel.com/en/discussion/12522/remote-access-vpn-wizard-for-secuextender-ipsec-and-non-secuextender-ipsec-vpn-clients#latest
Android 12 and ikev2
https://community.zyxel.com/en/discussion/12940/android-12-and-ikev2
- 439 Beta Program
- 191 Nebula Ideas
- 6.2K Security
- 467 USG FLEX H Series
- 307 Security Ideas
- 82 Switch Ideas
- 281 Service & License
- 440 News and Release
- 4.3K FAQ
- 93 Security Highlight
