Usg210 ike v2 vpn connection with samsung s22
Manuel13
Manuel13 Posts: 7 image  Freshman Member
Second Anniversary
Hi
The new android phone support only ike v2 VPN.
I try config vpn server role, but not work...
I try with certificate and with only password...but i have a problem to connect.
I install StrongSwan app...but i have same problem.
Have you a tutorial for vpn ike v2 for android phone?
Manuel
