Switch GS2210 Series - V4.50 Patch 4 Firmware Release
Zyxel_Adam
Zyxel_Adam Posts: 429  Zyxel Employee
Zyxel Certified Network Administrator - Nebula 25 Answers First Comment Friend Collector
edited July 2021 in Switch New Release
Zyxel Switch GS2210 Series
Release Note
December, 2020
Firmware Version on all models
(Click Hyper link to download the firmware directly)
Zyxel GS2210-8    - V4.50(AASP.4)
Zyxel GS2210-8HP    - V4.50(AASQ.4)
Zyxel GS2210-24    - V4.50(AAND.4)
Zyxel GS2210-24HP  - V4.50(AANE.4)
Zyxel GS2210-24LP  - V4.50(ABEO.4)
Zyxel GS2210-48    - V4.50(AAHV.4)
Zyxel GS2210-48HP  - V4.50(AAHW.4)
New Feature and Enhancements
CLD=Cloud mode, STK=Stacking mode, STD=Standalone mode
No.
CLD
STK
STD
1.
Enable IPv6 Address Auto Configuration by default.
V
2.
Enable DHCPv6 client mode by default.
V
3.
“enable“ command would be disabled by default.
V
4.
Users with privilege 3 are allowed to turn on/off Locator LED.
V
5.
Display both IPv4/IPv6 address on neighbor page.
V
6.
ZON supports IPv6 address.
V
7.
Support Vendor-ID based VLAN.
V
8.
Apply new login interface.
V
9.
Support Auto PD recovery.
V
Bug fix
No.
Bug fix
CLD
STK
STD
1.
[eITS#170900154] Hardware monitor detect abnormal value.
V
2.
[eITS#180400205] Snmpwalk gets error output in TIME-RANGE-MIB.
V
3.
[eITS#180701100] while configuring TACACS+ as login method one and local as login method two, users can log in switch from both methods. It should follow the rule that only when method one is down then method two can work.
V
4.
[eITS#180800687] If the shared key of TACACS+ server is mismatched, switch will not consider the server is unreachable and will not change to other login methods.
V
5.
[eITS#190200916] Switch may be randomly rebooted if dot1x guest VLAN multi- secure mode is enabled.
V
6.
[eITS#190201160] The device will reboot unexpectedly due to LLDP memory leak.
V
7.
[eITS#190300525] Handling IPv6 routing may cause switch crash and reboot.
V
8.
[eITS#190500548] Classifier entry cannot be deleted after the binding policy rule was deleted in inactive state.
V
9.
[eITS#190500189] Switch crashes when receiving LLDP packet with incorrect length of TLV.
V
10.
[eITS#190700015] Can’t display IP source guard binding info on web GUI.
V
11.
[eITS#190800016] PD gets an incorrect allocated power value when Power-via-MDI is enabled along with PoE Max Power.
V
12.
[eITS#190800433] Can’t display the correct information when configuring “Show IPv6 neighbor.
V
13.
[eITS#190800796] Switch crashes when receiving particular IPv6 MLD packets.
V
14.
[eITS#190900353] Lost IPv6 management when IPv6 MLD snooping proxy is enabled.
V
15.
[eITS#191100449] Switch will randomly warm-reboot after a lot of continuous SSH login.
V
16.
[eITS#200200647] IPv6 DHCP snooping untrusted port is not working.
V
17.
[eITS#200500197] HTTP login switch will fail when using RADIUS authentication.
V
Please refer to the Download Link for more details.
Adam
  • Mike_Mike
    Mike_Mike Posts: 5
    Friend Collector
    The link is no longer working.
    Please provide the rom file for the GS2210-8HP switch. I have it on my desk, lost password, is there any other way to reset to factory defaults? The inside switch doeas not appear to do any other thing than useless reboot.
    Please provide the rom, please !
  • Zyxel_CSO
    Zyxel_CSO Posts: 481  Zyxel Employee
    5 Answers First Comment Friend Collector Eighth Anniversary
    edited June 2022
    Hi @Mike_Mike,
    The "Download link" is to redirect user to a GS2210 release note.
    If you would like to download the .rom file, please download the file on the top of this page.
    Thanks,
    Zyxel Nebula Support
  • valeri
    valeri Posts: 1
    Hi there,
    I have gs2210-8hp v4.5 patch 2. I have issues with combo ports and checked that in patch 3 there is bug fix for that, but I can't download patch 3, because the link does not work, so finally my question is whether the patch 4 contains all bug fixes from previous patches, so I can update directly to patch 4?
    10x in advance!
  • Zyxel_Adam
    edited August 2022
    Hi @valeri,
    Please check our EOL list and search for "GS2210" to donwload latest patch.
    Or download the V4.50 patch 2 firmware by clicking here.
    Adam
