ZyWall 110 SSL-VPN and SecuExtender 4.0.2.0 / Can`t connect
our System:
ZyWall 110
Firmware V4.32
Problem:
If we restart our ZyWall 110 the SSL-VPN connection works great but after some hours we can`t connect to the ZyWall, after restart again they works great.
Somebody know what they are having Problems?
Thanks for any help.
The SSL VPN tunnel is base on HTTPS protocol. But it will effects by some of environment issue.
(a) PC interface status has changed.
(b) PC WiFi has roamed to other WiFi.
(c) If PC is behind NAT router, NAT Router WAN IP address has changed.
(d) PC is unable connect to server at that moment.
(e) PC routing stability issue.
Could you provide routing and trace route information to us? (The information must coming from same PC)
(1) Before establishing VPN tunnel.
Enter CLI command: route print
Enter CLI command: tracert [Internal IP]
(2) After VPN tunnel is established and without problem.
(3) When symptom happening.
- 441 Beta Program
- 210 Nebula Ideas
- 539 USG FLEX H Series
- 340 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 464 News and Release
