USG100 latest firmware?
mMontana
mMontana Posts: 1,437 image  Guru Member
According to the PDF file here...
All dates "End of" about USG 100 are 2018/06/30. That's fine. But...
Latest "support file" for firmware into download section from Zyxel is 3.30 P7, dated January 2015.
And I found a 2016 WK41 file, named "3.30(AQQ.8)ITS-WK41-r74145 / 1.12 / 2016-10-13 21:14:58". Which currently work quite nicely with my device.
But according to date... is there any "lab firmware" with more corrections update dated closer to 30/06/2018?
Feel free to link that to me...
And if it's "safe enough" to deliver to customer, consider to make it available....
ReUse
Repair
Recycle
For some applications, ReUse is Wonderful ;)
  • Zyxel_Stanley
    Zyxel_Stanley Posts: 1,398 image  Guru Member
    @mMontana
    The latest formal version for USG100 is 3.30P7. It fixed major issues we found.
    The latest patch firmware for USG100 is 3.30P7-WK48 it fixed minor issues that found.
    If you need latest version, you can have a try on version WK48.
  • Zyxel_Stanley
    @mMontana
  • mMontana
    Thanks and already downloading... WK48 is related to which year?
  • mMontana
    UP! Still would like to know the answer, if possible.
  • Zyxel_Stanley
    Hi @mMontana
    The firmware was released at DEC 2016. :)
  • mMontana
    Thanks a lot :)
  • Westbike01
    Westbike01 Posts: 2 image  Freshman Member
    Where can I get this firmware for the USG 100 please ?
  • mMontana
    edited October 2024
    You can. There's a link in the thread. Try to click it.
    But really… I'd not use USG 100 device nowadays. Latest firmware is 8 years old, so "security" currently is not a thing on that device.
