USG100 latest firmware?
According to the PDF file here...
All dates "End of" about USG 100 are 2018/06/30. That's fine. But...
And I found a 2016 WK41 file, named "3.30(AQQ.8)ITS-WK41-r74145 / 1.12 / 2016-10-13 21:14:58". Which currently work quite nicely with my device.
But according to date... is there any "lab firmware" with more corrections update dated closer to 30/06/2018?
Feel free to link that to me...
And if it's "safe enough" to deliver to customer, consider to make it available....ReUse
Repair
Recycle
For some applications, ReUse is Wonderful
@mMontana
The latest formal version for USG100 is 3.30P7. It fixed major issues we found.
The latest patch firmware for USG100 is 3.30P7-WK48 it fixed minor issues that found.
If you need latest version, you can have a try on version WK48.0
@mMontana
If you need latest version, you can have a try on version WK48.0 -
Thanks and already downloading... WK48 is related to which year?
UP! Still would like to know the answer, if possible.
Thanks a lot
Where can I get this firmware for the USG 100 please ?
Thanks0 -
You can. There's a link in the thread. Try to click it.
But really… I'd not use USG 100 device nowadays. Latest firmware is 8 years old, so "security" currently is not a thing on that device.
- 588 USG FLEX H Series
- 477 News and Release
