Upgrading Firmware for a USG60 from V4.13(AAKY.0) to 4.32(AAPH.0)
Best Answers
It might be best to go from V4.13 to V4.20 here
ftp://ftp2.zyxel.com/USG60/firmware/
then log on here and get V4.32
5 -
Hi @Stephan
You can upgrade firmware by this steps:
4.13 > 4.20 > 4.30 > 4.32
In firmware upgrading process may cased your configuration been reset.
If you would like to keep your configuration, you can send your configuration to me by private message, and I can help to verify it first.
I'll send you download link by private message.
5
5 -
Hi @Stephan
5 -
Hey guys!Thanks. I ended up going V4.13 -> V4.20 -> V4.32.Configuration was kept, so no issues there.I now try to set up VPN from internal ports, since this should be supported now per https://businessforum.zyxel.com/discussion/1332/usg-60-l2tp-ipsec-vpn-not-working-from-local-lan2/p1?new=1I'll see if I can figure it out on my own for now.
Thanks for sharing. We do have the exact same situation here!0
- 588 USG FLEX H Series
- 477 News and Release
