Vpn ikev2 re-establishing if the option fall back to primary is selected
I have a usg flex 700 behind a nat, establishing vpn with another site.
I can see that if the option in the gateway settings "fall back to primay peer" is selected, and it is set to 3600 seconds, every hour the vpn has a disconnection.
That happens even if the vpn is connected to the primary peer ip.
So I am wondering, is there a specific log that can help me discover if there is something in the middle disturbing it?
Regards
Regards
WAN connections are verifing the connection status? On remote (calling) and local (waiting) side.0
Hi @Hoygen83Can you share the screenshot of the 3600 seconds parameter configuration with us?BTW, while the VPN disconnects you can navigate the Web-GUI path: Monitor->Log -> View Log to see if there is any VPN disconnection related log. If so, you can share the log with us, too. Maybe we can analyze that for you, thanks.0
Hi @Hoygen83
One more question, if the VPN is disconnected, does the traffic still can be passed via the VPN tunnel? Or not? Thanks.0 -
when it is disconnected it will not pass.
Hoygen83
Thanks for your update. Can you share your VPN-related settings screenshots with us? BTW, while the VPN disconnects are there any suspect logs relates to disconnection on the Monitor log?0
- 397 Beta Program
- 2.1K Nebula
- 116 Nebula Ideas
- 78 Nebula Status and Incidents
- 5.1K Security
- 52 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 70 Switch Ideas
- 907 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 211 Service & License
- 332 News and Release
- 71 Security Advisories
- 21 Education Center
- 1.9K FAQ
- 880 Nebula FAQ
- 415 Security FAQ
- 221 Switch FAQ
- 195 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 137 Service & License FAQ
- 73 About Community
- 63 Security Highlight
