GS 1910 24 hp config question
blueprintcapital
I inherited a network system without any info. I manage an apt building. The system has internet coming in to the modem, then it goes into a Juniper WLC100 WLAN controller that is EOL, then it runs into the GS 1910 24 hp. Is the WLAN redundant? Can I eliminate it and just run the feed from the modem or even a router into the Zyxel and manage my APs and Vlans without the WLAN?
Hi @blueprintcapital
May you share more detail about WLAN redundant? What function do you expect WLAN redundant can do?
And do you mean "Can I eliminate it" is to remove your controller and connect Zyxel GS1910-24HP to your Modem or a router?
Zyxel Melen0 -
Zyxel_Melen said:Hi @blueprintcapital
Remove the WLAN controller, you need to check out all your APs' IP address and setup one by one.Zyxel Melen0 -
Hi @blueprintcapital,
Since didn't see you reply for few days, may I know is there any thing I can help?
In addition, you just need to make sure your switch have correct VLAN setting then the Wifi will work.
Zyxel Melen0
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 454 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 278 Service & License
- 435 News and Release
- 91 Security Highlight
