ZyWall 110: SSL VPN disconnecting problem after update to 4.72 firmware
Hello @MSA,sorry, wrong link on my last post, thanks for you correction.Here is the correct link for Zywall 110 4.72 WK25. This version fixs the SSL VPN disconnection issue.James0
Hello @MSA,Welcome to Zyxel Community!Please update to our latest 4.72 WK25 firmware, please refer to the link below to download it:
https://fwstore-zsdn-cloud-zyxel-com.s3.us-east-1.amazonaws.com/465AAAA0C0.zipThe 4.72 WK25 firmware fixed SSL VPN disconnection issue, please give it a tryJames0 -
Hello @Zyxel_James.
Wrong link. Do you mean this
https://fwstore-zsdn-cloud-zyxel-com.s3.us-east-1.amazonaws.com/4.72/WK20/472AAAA0ITS-22WK20-r103984.zip
But this is 4.72 WK20.
Page updated this morning, 4.72 WK25. 5.30 still WK20.
Thanks everyone. Will try 4.72 WK250
We are still on 4.71 with our USG110 and plan to updated soon. Is it recommended to directly use 4.72 WK25 for USG devices instead of the regular 4.72 AAPH.0?Or should we use WK25 only in case we experience SecuExtender Problems after updating with 4.72?0
Personal opinion only...
- Update ASAP (with reboot) on 4.72.
- Update right after (without reboot) on standby partition on 4.72WK25
- Test SecuExtender. Probably won't work.
- If it does not work, reboot on 4.72WK
- Test SecuExtender. Probably it will work
Than, take note of every change of the configuration. Few releases ago I had some issues during editing configuration between WK file and "non WK" file, which lead to some issues on subsequent update.Rollback to 4.72 with a reboot should allow you to have a fully updated .72 configuration for a smoothless upgrade for the last firmware that I am expecting from zyxel into 2022. Also the last one for the devices.
- 221 Nebula Ideas
- 612 USG FLEX H Series
- 53 Wireless Ideas
- 483 News and Release
