Enter Devices behind Firewall
Chnochi
Chnochi Posts: 2
Hey there I have the Zywall USG-20W. No I want to Enter my devices on vlan 1(192.168.1.1/24) from my wan network (192.168.0.1/24). How can I set up this, because my Configuration isn't working.
    PeterUK Posts: 3,893  Guru Member
    This will not work unless you can do static route on router 192.168.0.1
    The reason for this is USG-20W on WAN gets a IP 192.168.0.1/24 and let say 192.168.0.50 want to connect to 192.168.1.60 the router at 192.168.0.1 will not know to forward 192.168.1.60 to USG-20W which is where static route is needed but this must be done on the 192.168.0.1 router.
  • jasailafan
    jasailafan Posts: 193  Master Member
    You need to add a static route on the device (192.168.0.1) just like PeterUK suggested.
    destination IP: 192.168.1.0
    subnet mask: 255.255.255.0
    gateway IP: 192.168.0.x (the wan IP of Zywall USG-20W)
