USG210 - problem with 4G backup
HI,
My configuration :
USG210 Wan1 fiber ISP1 - Wan 2 4G ISP2 - Lan 1 Windows server 2016 DC
The configuration works but when the quota of the 4G is zero there is no internet on the Lan and I have to unplug the Wan2 for the USG210 to work simply with the Wan1.
the two Wans are static and the Lan no DNS, it is the Windows server which manages them.
what can I do to rectify this? Thank you for your answers.
Claude.
Will it work if only connected to wan2 (dongle) ?
Have you set up the connectivity check on your cellular interface? or any WAN trunk settings?I think it could be considered connected even quota runs out. If you have connectivity check settings, it would be considered disconnection when the quota runs out. you can give it a try.0
Thanks for your replies.In fact when 4G quota is zero there is still a connection 4G (the USG 210 sees a connection working on wan 2) but very restricted so Internet on the Lan doesn't work.How to force US210 to go on Wan1 by default ?
osake_li_09 said:Have you set up the connectivity check on your cellular interface? or any WAN trunk settings?I think it could be considered connected even quota runs out. If you have connectivity check settings, it would be considered disconnection when the quota runs out. you can give it a try.
Hello @Claude,I recommend WAN trunk.Configuration > Network > Trunk > Add an User ConfigurationLoadSet up wan1 as Active, cellular1 as Passive, and the Load Balancing Algorithm is Spillover, then the traffic will be transmitted to wan1 first unless wan1 loading has full.Or you can try policy route.Source: LAN1, Destination: Any, Next-Hop: wan1, enable "disable policy route automatically while interface link down".This method will make LAN1 traffic go through wan1 unless wan1 link down
Reference:
https://community.zyxel.com/en/discussion/10918/usg110-wan-failover-policy-routes-vs-wan-trunk-settingsWAN trunk -> failover to passive interface. https://www.youtube.com/watch?v=jogTfujoHkIPolicy route -> ignore policy route rule from table. https://www.youtube.com/watch?v=6XhyZ3KWaxc
Regards,
James0 -
Many thanks James. I go to try this !0
- 439 Beta Program
- 2.8K Nebula
- 198 Nebula Ideas
- 6.3K Security
- 483 USG FLEX H Series
- 319 Security Ideas
- 83 Switch Ideas
- 46 Wireless Ideas
- 284 Service & License
- 451 News and Release
- 4.3K FAQ
- 93 Security Highlight
