TR-069 on VMG8623-T50B
dolanp
in Home Router
Hi all,
Can someone direct me as to where we can find the config settings on a VMG8623-T50B modem. The modem is currently running firmware version 5.50
Hello @dolanp
Looking at the user guide at https://spdl.zyxel.com/VMG8623-T50B/user_guide/VMG8623-T50B_1.pdf it does not mention TR-069 so it may not be supported by the router.
Kind regards,
Tony0 -
It is supported, I've been using it.
You need to login as Supervisor to be able to see the TR-069 page on the GUI.1 -
Hello @Df_Wide
That is good news.
What version of firmware have you got that TR-069 work in? Is it newer that 2019 release date?
Where did you get the supervisor password please?
Kind regards,
Tony0 -
Hi @tonygibbs16
Not sure when it's from: V550ABPM5C0
If you're an end user you need to contact your ISP to obtain the supervisor pw (they might refuse if you're still in contract/using their connectivity).
Otherwise contact your supplier for the FW and supervisor password.1
- 588 USG FLEX H Series
- 477 News and Release
