Full 2.5Gb Ethernet firewall lineup. With 802.11AX.
mMontana
mMontana Posts: 1,468 image  Guru Member
edited July 2024 in Security Ideas
With cheap models.
Versions without bundles also.
4 votes
Active · Last Updated
  • dkyeager
    dkyeager Posts: 71 image  Ally Member
    1Gbps ports are a clear limitation when we already have 5Gbps to the home with AT&T Fiber and other ISPs, with projections of more 10Gbps connection in the immediate future.  Also expected to be able to aggregate (LAG) these for maximum throughput and redundancy.
  • Omnia
    Omnia Posts: 60 image  Ally Member
    +1
    The LAG on Zyxel current design with say two ports is limited rate as one port.
    I would also expect the SPI to be a min of 2600Mbps
