Download speed slows down after a while on wifi but not on ethernet.
Fritzbox 7530. 802.11ac (WiFi5 for non tech-talkers), 866mbps with 5ghz, 450mbps with 2.4ghz. So not that blazing fast but... quite a good router with a nice but not top-notch wireless arrangement.NWA3160-N. 802.11n (WiFi4) plus 802.11a/b/g (Wifi1+2+3). 300mbps on 2.4ghz OR 54mbps on 5.0 ghz.It's like competing a newer, lighter, turbocharged and hybrid car versus a nice, plushy, comfortable and heavy like a ship old top notch sedan at the drag strip.Race lost and burned so much more fuel.On a 802.11n (WiFi4) USG20W i cannot go much higher than 3.5mbyte/s of sustained LAN transfer rate, and it slow further when another device (tablet) asks for updates on android.As a personal opinion, a WiFi6 at least AP is suggested for a long term upgrade and for much more bandwidth stable performance for concurrent accesses. Most of the improvement won't be seen until most the clients won't be Wifi6 compliant, but the OFDMA will drop a lot the data collisions, allowing in the same 20mhz channel to boost concurrent data transfer without interfering with other clients transfers.
Hi, @alpha099
Welcome to the Zyxel Community!
We have received your message.
Could you kindly help us to tell which band SSID you used?
Since wireless transmission may be impacted by many reasons, such as wireless signal interference, quality of the wired connection cable, channel loading, and Half-duplex mechanism.
The above factors all cause bad users experience and are hard to use.
For your scenario, we would suggest you change the channel and adjust the radio direction and help us to observe whether the symptom is solved or not.
But since the NWA3160-N is a Wi-Fi 4 product, in which both hardware and protocol are old generations, there are clients and applications that may require more bandwidth to transfer, we would more recommend replacing them with new generation products.
If you are willing to give our AC AX product a try, the below Access Point product information is for you!
Link: Wireless | Zyxel
If there is still another assistance that we could help with,
Please do not hesitate to contact us.
Have a nice day,
Thank you.
Best Regards,
HsinBo
Zyxel_HsinBo
Hi, @mMontana
Thanks for your kind assistance,
The reply from you is professional and clear!
Have a nice day,
Thank you!
Best Regards,
HsinBo
Zyxel_HsinBo
- 439 Beta Program
- 191 Nebula Ideas
- 6.2K Security
- 468 USG FLEX H Series
- 308 Security Ideas
- 82 Switch Ideas
- 281 Service & License
- 440 News and Release
- 4.3K FAQ
- 93 Security Highlight
