L2TP IPSec VPN with AD Authentication
trying to get L2TP IPSec VPN with AD Authentication working. Followed this "https://community.zyxel.com/en/discussion/13087" How to Set Up L2TP IPSec VPN with AD Authentication on Nebula
Issue I am running into is no matter what account I use we get "User ***** has been denied from L2TP service.(Incorrect Username or Password)"
Maybe your current configuration cannot correctly query your AD?1
Hi @pcservice,
Can you post Windows AD event log when l2tp client login? We may need to check if there are any authentication error/fail event log in Windows AD.
I ended up creating a new domain admin account to use for AD, this worked fine. The original admin account I was using had all the same rights as the new one I created, and It was not showing any errors in the logs with the account.0
Not sure if it was related to Windows AD issue or Nebula issue. Assume the issue happens again. please help us to check if there is any error/warning event in Windows event log.0
- 244 Nebula Ideas
- 6.9K Security
- 808 USG FLEX H Series
- 392 Security Ideas
- Threat Watch!
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 333 Service & License
- 541 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 89 About Community
- 124 Security Highlight
