ZyWall 110 SSL-VPN and SecuExtender 4.0.2.0 / Can`t connect
swissp
swissp Posts: 2 image  Freshman Member
edited April 2021 in Security
Dear Zyxel
our System:
ZyWall 110
Firmware V4.32
Problem:
If we restart our ZyWall 110 the SSL-VPN connection works great but after some hours we can`t connect to the ZyWall, after restart again they works great.
Somebody know what they are having Problems?
Thanks for any help.
  • Zyxel_Stanley
    Hi @swissp
    I will send you private message for check this issue more detail.
  • artit
    artit Posts: 10 image  Freshman Member
    Hi @swissp
    I have got the same problem.
  • Zyxel_Stanley
    The SSL VPN tunnel is base on HTTPS protocol. But it will effects by some of environment issue.
    (a) PC interface status has changed.
    (b) PC WiFi has roamed to other WiFi.
    (c) If PC is behind NAT router, NAT Router WAN IP address has changed.
    (d) PC is unable connect to server at that moment.
    (e) PC routing stability issue.
    Could you provide routing and trace route information to us? (The information must coming from same PC)
    (1) Before establishing VPN tunnel.
    Enter CLI command: route print
    Enter CLI command: tracert [Internal IP]
    (2) After VPN tunnel is established and without problem.
    (3) When symptom happening.
