UAG 5100 how to optimize the two Wan available?
greg
greg Posts: 32 image  Freshman Member
First Comment Sixth Anniversary
Dear  Sir ,i have a UAG 5100 with two wan connexions Wan1 20M/20M and Wan2 15M/ 15M ,usually i use them so but in failover purpose,but not i see that the Lan consumption have increase mor emore because new streaming web and others.
Now i face bandwitch saturation in Lan ,how can i use the second wan2 bandwitch to have 35M/35M avaible for my Lan?
best regards
  • Zyxel_Cooldia
    Zyxel_Cooldia Posts: 1,539 image  Guru Member
    Hi @greg,
    With Load Balancing Algorithm setting, assume both wan interface are active mode,  it can balance the traffic load between two wan interface. The device overall bandwidth to Internet can reach 35/35M. Just confirm if both wan interface are active mode.
  • greg
    Thanks sir,but I have not understand what to do exactly step by step.?I have last firmware
  • Zyxel_Cooldia
    edited June 2022
    Hi @greg,
    The device overall bandwidth can reach 35/35M. but it's not something like aggregation for wan 1 and wan 2 bandwidth. We would suggest enlarge Internet speed if overall bandwidth is full loading.
  • greg
    ok wchich configuration to do so The device overall bandwidth can reach 35/35M in case?please help
  • Zyxel_Cooldia
    Hi @greg,
