Firmware Upgrade NBG418Nv2
m_ghNBG418Nv2
in Home Router
Need the latest Firmware Upgrade for NBG418Nv2
Please help!
Please help!
Thank you Zyxel_Jerry
Having updated the firmware, trouble persists:
When I have ethernet cable connection to Modem, it is ok; but when I use Wi-Fi connection I have permanent troubling disconnections/reconnections...
I tried also reset factory of router but not efficient!
OS: Win 10
Modem: Zyxel p-600 seriesSystem Operation Mode: Router
Channel Selection: Auto
Connection Type: Ethernet (DHCP)0 -
Hi @m_ghNBG418Nv2
Please set the NBG418Nv2 as a DHCP server and connect it without an ethernet cable to the Modem.
Try to connect the Wi-Fi of NBG418Nv2 and check does the disconnection issue happen still persists on the NBG418n-v2.
We can check does the issue happen on the wifi or on the modem.
You can private message us more information if you have concerns to share the information in the article.0
- 588 USG FLEX H Series
- 476 News and Release
