Geo-IP country database download has failed
Today there was a problem with manual updating the Geo-IP database to 20220706 from the one of location (there is no problem from the other location). Most likely a problem with the local ISP, how can I check the availability of the server, which address need to check?
Hi @a1601
We suggest you can press the “Update Now” button to check if you already have the latest GeoIP database.
BTW, whenever you trying to update the Geo IP database, you would inquire the FQDN ”service-dispatcher.cloud.zyxel.com ” firstly then to check if you need to update the latest Geo IP database, as below:
.0
- 3K Nebula
- 222 Nebula Ideas
- 620 USG FLEX H Series
- 350 Security Ideas
- 53 Wireless Ideas
- 488 News and Release
- 108 Security Highlight
