ATP 200: Multicast and broadcast routing across VLANs to enable media sharing protocols.
mocr
I have created several segments (VLANS) in my network to increase security of my home network. One VLAN is for computers and mobile phones, another VLAN is for data servers (e.g. NAS), another VLAN is for media players (e.g. TVs, SONOS audio players or printers) and another VLAN for IOT devices like Philips Hue. Unfortunately standard applications like SONOS app or Spotify connect or Apple Print / AirPrint or DLNA or Chromecast or Philips Hue are not working in this network design. What I was able to investigate is that the multicast / broadcast protocols like Bonjour, UPNP, DLNA uses protocol TTL parameter set to 1 and cannot be routed across different VLANS (the packet is discarded by the router).
Do you have any suggestion how to resolve this issue or is it a new "Feature request" for ATP / USG product family?
Still I am not sure that only TTL parameter increase resolves this scenarion.
Thanks for help,
Radek
3
Hi @mocr
Thank you for your reply.
We don’t support certain scenario currently and will put this suggestion into idea for further evaluation.
Hi,Is it possible somehow to track this in the "idea" backlog and somehow support the resolution / implementation? I believe this scenario is valid for SMBs when BYOD is supported and also for consumers who have bought this equipment to increase their home IT security.Thanks a lot for your help.Radek Moc0
As I am still searching the information how to resolve the problem I found out that something called mDNS reflector should resolve that.Some info is here https://github.com/Gandem/bonjour-reflector and here https://docs.paloaltonetworks.com/pan-os/10-0/pan-os-new-features/networking-features/bonjour-reflector-for-network-segmentation.html and also here https://www.vivitek.eu/Download/Documents/Enabling_iOS_Mirroring_in_a_Multiple-subnet_Environment.pdf.Can you consider implementing such feature directly into ATP firmware as that would be best addition to IGMP proxy functionality and (probably) definitely would resolve this issue?Thanks a lot for your answer.Radek
+1 for this feature request, the need has come up to isolate several sonos speakers on a separate vlan1
As I am still searching the information how to resolve the problem I found out that something called mDNS reflector should resolve that.Some info is here https://github.com/Gandem/bonjour-reflector and here https://docs.paloaltonetworks.com/pan-os/10-0/pan-os-new-features/networking-features/bonjour-reflector-for-network-segmentation.html and also here https://www.vivitek.eu/Download/Documents/Enabling_iOS_Mirroring_in_a_Multiple-subnet_Environment.pdf.Can you consider implementing such feature directly into ATP firmware as that would be best addition to IGMP proxy functionality and (probably) definitely would resolbe this issue.Thanks for your answer.Radek
Is somebody from Zyxel reading this thread? I would appreciate the information if this is being considered for implementation in future firmware updates.
Every company wants to support BYOD and without this functionality the employee experience will not be positive.
Please solve this problem for all of us.
Thanks,
Radek0 -
+1 for this feature request. bumping it for visibility
regarding IGMP i would like to raise awareness to IGMPv3 for IPTV over the PPPoE feature, would likely also work for Multicast between VLANs.
https://community.zyxel.com/en/discussion/14730/support-igmpv3-over-pppoe-and-ssm-features#latest
Maybe there is some common ground...0 -
Yes please . . . +1
Please, it's a very important feature
- 396 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 5.1K Security
- 86 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 915 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 211 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2K FAQ
- 912 Nebula FAQ
- 419 Security FAQ
- 237 Switch FAQ
- 207 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 139 Service & License FAQ
- 72 About Community
- 62 Security Highlight
