New Small Business Access Point - NWA50AX and NWA55AXE has been released!
Zyxel_Bella
Zyxel_Bella Posts: 560 image  Zyxel Employee
Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Administrator - Switch 50 Answers
edited September 2021 in WirelessLAN New Release
New WLAN Access point is supported. A brand new small business AP, NWA50AX and NWA55AXE, is on-boarding to Nebula platform in this release. Small Business Access Point comes with right-fit feature set and simplest configuration make it the best choice for small-business.
Following table is the supported feature matrix and limitation while operate on Nebula control center.
Note: The features not be listed in the table are not supported and shall not be applicable.
  • NL_
    NL_ Posts: 3 image  Freshman Member
    I'm currently running custom firmware datacode: "V6.25(ABZL.8)-DF-2022-05-09" for my NWA55AXE because of a bug.
    When will this fix be integrated in the next "real" official firmware update?
    Best regards
    Floris
  • Zyxel_CSO
    Zyxel_CSO Posts: 500 image  Zyxel Employee
    5 Answers First Comment Friend Collector Ninth Anniversary
    edited May 2022
    Hi @NL_
    We usually patch the bug fix in next major version release.
    It will record in release note, thank you.
    Regards,
    Zyxel CSO
    Zyxel Nebula Support
  • NL_
    Great, thanks for the info.
    Regards
    Floris
  • NL_
    I see firmware "6.25(ABZL.10)C0" is released.
    Can you tell me if the fix from "datacode: "V6.25(ABZL.8)-DF-2022-05-09" is included in this release?
    Regards
    Floris
  • Zyxel_Bella
    Hi @NL_
    Yes, the solution of V6.25(ABZL.8)-DF-2022-05-09 is included in V6.25(ABZL.10)C0.
    Please arrange preferred time to upgrade. Thanks!
    BR,
    Bella
