Port Forwarding on USG210
Ok, so I have sorted it out. Selecting WAN interface on the NAT does not allow it. but selecting WAN_PPP, and it works.
thanks to everyone that contributed to my thread your help and efforts are greatly appreciated!.
There's a FAQ post about how to configure port forwarding.
https://businessforum.zyxel.com/discussion/1448/how-to-setup-port-forwarding-to-my-internal-rdp-pc
Dear @Derrick
we have a example here with video
https://support.zyxel.eu/hc/en-us/articles/360001390934-NAT-Rule-Configuration-on-a-USG-Port-Forwarding-
Or the tutorial from onesecurity:
http://onesecurity.zyxel.com/img/uploads/ZLD Series Port Forwarding CR.pdf
Thank you for the reply I will try this again and give feedback.
thanks,
Derrick0 -
The thing is I can see the router DROP the request in the log. But it does not tell you what rule is causing the DROP. is there anyway to find out?
thanks.
Derrick0 -
does it look like this? saying match default RULE DROP
Have you made a firewall rule to allow from WAN to LAN1?
And have you made a NAT rule for Virtual Server?
I did WAN to LAN1, Virtual Server. yes. I wish there was a way for the router to tell you what the Rule is implementing the DROP.0
But you also need to make a firewall rule have you done that?
I am deleting everything I have made. and will remake them. and report back thanks.0
- 441 Beta Program
- 293 Service & License
