XGS1930-52HP Switch port reset via cli
Hi @Tobihoby
Welcome to Zyxel community!
Since the XGS1930-52HP is a smart managed switch, it does not support CLI command.
You can use PWR cycle function to restart your PD(like CAM) via Web GUI.
Please go to Status > Neighbor and click the cycle button of the PD connecting port which you want to restart.
1. Click Neighbor
2. Click the cycle button of the PD connecting port that you want to restart. I use port 2 as an example.
Zyxel Melen1
Hi @Tobihoby
1. Click Neighbor
Zyxel Melen1 -
Prior to the Xs1930 every time I was uploading between 2.5Gbps and 1Gbps devices I was getting around 500 Mbps. Now with the XS1930 I can get the ful1 1Gbps or https://testmyspeed.onl/.
- 3K Nebula
- 223 Nebula Ideas
- 6.6K Security
- 633 USG FLEX H Series
- 355 Security Ideas
- 85 Switch Ideas
- 54 Wireless Ideas
- 301 Service & License
- 493 News and Release
- 109 Security Highlight
