[Release Note] Access Point Series - V6.40 P6 firmware has been released!
Access Points Firmware Release Note V6.40 Patch 6
Date: July 14, 2022
Supported Platforms
NWA110AX V6.40(ABTG.6)
NWA1123ACv3 V6.40(ABVT.6)
NWA210AX V6.40(ABTD.6)
NWA220AX-6E V6.40(ACCO.6)
WAC500 V6.40(ABVS.6)
WAC500H V6.40(ABWA.6)
WAX510D V6.40(ABTF.6)
WAX610D V6.40(ABTE.6)
WAX620D-6E V6.40(ACCN.6)
WAX630S V6.40(ABZD.6)
WAX640S-6E V6.40(ACCM.6)
WAX650S V6.40(ABRM.6)
New Feature and Enhancements
1. Support new AP model. The NWA220AX-6E, WAX620D-6E and WAX640S-6E are added to Nebula in this release. NWA220AX-6E is a NebulaFlex AP that supports standalone and Nebula cloud managed mode; WAX620D-6E and WAX640S-6E are NebulaFlex Pro AP that comes with 3 management modes: standalone, controller managed and Nebula cloud managed modes. It comes with 1 year Nebula Pro Pack license bundled.
2. The U/I of WiFi settings are enhanced for WiFi 6E (6GHz).
3. Support more radio settings correlated while selecting deployment template on Nebula control center.
4. Added MAC authentication fallback option that allows a wireless client to bypass captive portal if a station passed MAC authentication on Nebula control center.
5. Improve log wordings to easy of read and more detail information for troubleshooting.
6. Support WPA3 security option on Standalone AP wizard.
7. Device login page enhancement to add more on-boarding information.
Bug Fix
Empty column stands for the mode is unaffected.
Mode |
CLD |
MGNT |
STD |
1. [eITS: 211000247] [Symptom] Cannot get any of the access points to upgrade their firmware |
V |
2. [eITS: 211200358] [Symptom] Fast roaming doesn't work with DPPSK, clients get default vlan IP after roaming |
V |
3. [eITS: 220200710] [Symptom] When user set Emoji on the default SSID, no pop-out window |
V |
V |
V |
4. [eITS: 220100520] [Symptom] Fix TCP port 83/84 need to be turned off problem when using vulnerability scanning |
V |
V |
V |
5. [eITS: 211200432] [Symptom] configure dynamic VLAN. Clients get original SSID VLAN IP |
V |
6. [eITS: 220200256] [Symptom] Mesh SSID is visible and called ’smart_mesh’ and ’SG_xxxxxxxx’ |
V |
Known Issue
Mode |
CLD |
MGNT |
STD |
1. [eITS: 220601044] [Symptom] Accounting packet missing Framed-IP attribute |
V |
V |
V |
2. [eITS: 220400788] [Symptom] 802.11AX QCA model reboot caused by NSS abnormal |
V |
V |
V |
3. [Symptom] WAX620D-6E, WAX640S-6E, and NWA220AX-6E LED would still display blue light even if stations are connected. |
V |
V |
V |
4. [Symptom] WAX620D-6E, WAX640S-6E, and NWA220AX-6E ipv6 dhcp6 address-request not get ipv6 address |
V |
V |
V |
5. [Symptom] Client will disconnect if it first reauth fail after Fast Roaming |
V |
V |
V |
Limitation of Settings:
1. Due to hardware limitations, the AP throughput will be limited to 60Mbps when the rate limit, Dynamic VLAN assignment, DPPSK is enabled on NWA220AX-6E, WAX620D-6E, and WAX640S-6E.
hello,
not yet available on support website ? edit : released0 -
So where is it? My device is stuck on 6.10
- 395 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 5.1K Security
- 83 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 914 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 210 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2K FAQ
- 912 Nebula FAQ
- 415 Security FAQ
- 237 Switch FAQ
- 207 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 139 Service & License FAQ
- 72 About Community
- 62 Security Highlight
