AM3100-B0 NAT Problems
BjornSch
BjornSch Posts: 2 image  Freshman Member
Hi !
Any of you know how to add this configuration to NAT?
TCP: 3074,27014-27050
UDP: 3074, 3478, 4379-4380, 27000-27031, 27036
When I enter the Zyxel AM3100-B0 administration panel, I can only set the port, e.g. 3074, but I cannot set the range 27014-27050.
After changing the internet provider, the Zyxel AM3100-B0 router was delivered and installed. In the previous Router, I could select TCP / UDP and enter 3074, 27014-27050
In the Zyxel AM3100-B0 I can't
Please help
