USG Flex 500 Managed AP service node limit
dkyeager
What are the maximum number of APs managed by the USG Flex 500 with the
current standard license bundle? Originally was 8. I believe that was
increased to 16 in later firmware as mentioned in the release notes*. If
not 16, what is the license number to expand the Managed AP service node
limit?** Thanks
* edit: 5.10 [ENHANCEMENT] Product spec enlarge AP Groups.
Model WAS IS
USG FLEX 500 8 16
USG FLEX 700 8 32
ATP500 8 16
ATP700 8 32
ATP800 8 32
VPN1000 16 32
Model WAS IS
USG FLEX 500 8 16
USG FLEX 700 8 32
ATP500 8 16
ATP700 8 32
ATP800 8 32
VPN1000 16 32
** edit: These are all local APs, not remote. Looking for the original AP expansion license since remote VPNed traffic not required.
Hi @dkyeagerThanks for your feedback. Currently, the extended Managed AP license cannot be purchased on the Marketplace and the extended Managed AP license doesn't include Secure WiFi service, please contact your local Zyxel support for further information, you can refer to Where To Buy to see our local support contact information, thanks.0
Hi @dkyeager
Currently, the USG Flex 500 support 8 managed APs by default, but if you activated the Secure WiFi license service on the USG Flex 500 then the maximum managed APs numbers would enlarge to 72, please refer to this link for further reference, the Secure WiFi has two features that include Secure Tunnel and Managed AP Service.
You can purchase the Secure WiFi license on the Marketplace in the Individual Licenses option, as below:
Thanks.
Thanks, I was aware of this option. Hoping for a less expensive option such as prior 2 or 8 Access Point expansions just for local use. Might be more cost effective to buy separate hardware to effectively create separate groups.
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 125 Nebula Status and Incidents
- 6.3K Security
- 489 USG FLEX H Series
- 322 Security Ideas
- 83 Switch Ideas
- 46 Wireless Ideas
- 284 Service & License
- 455 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 95 Security Highlight
