Zyxel USG 60 stuck spinning on loading screen Easy Mode
natew365
natew365 Posts: 2 image  Freshman Member
First Anniversary
I switch the mode to easy mode and now the gui wont load. I have rebooted and cleared cache. Once I log in, it takes me the easy mode page, but will not load. Please help
    Do a reset load config from backup
    Really I don't see the point in easy mode might as well get a home router.
  • WJS
    WJS Posts: 156 image  Master Member
    5 Answers First Comment Friend Collector Third Anniversary
    Have you tried restarting ? Maybe the daemon is stuck .
  • Zyxel_Kevin
    Zyxel_Kevin Posts: 981 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate 100 Answers 500 Comments
    Hi @natew365
    Could you kindly share below information via Private Messages if the issue still ?
    - Diag-info.
    - connect console port and log in , then input "debug kernel console-level 8".
    collect all output messages for us.
    Thank you.
