Dx5401 cannot access configuration page after reset
VooDoo2U
VooDoo2U Posts: 1 image  Freshman Member
Hi, I wanted to reset all settings to factory, so I kept pressed reset button till power led blinked. ut then the router lost power and I cannot access the configuration page anymore. All leds behave correctly and also the lan ports works correctly. Also, I can access the internal FTP.
Do you have a recovery procedure to restore the firmware?
Thanks in advance for your help, will be very appreciated.
Dario
  • Liba
    Liba Posts: 211 image  Master Member
    First Comment First Answer Third Anniversary
    Hi VooDoo2U,
    It seems that you can successfully access the internal FTP.
    Maybe you need try to access the configuration page through HTTPS or HTTP or reopen the browser to try again.
