NWA5123-AC
joudeh1996
joudeh1996 Posts: 8
First Anniversary
edited May 2024 in Wireless
Hello Everyone
I have access point nwa5123-ac
It was working correctly
Today it couldn't boot up...the led still orange without blinking
Also it couldn't connect via ethernet
I try to reset it...but it's not responding
What to do?
  • smb_corp_user
    smb_corp_user Posts: 170  Master Member
    5 Answers First Comment Friend Collector Third Anniversary
    Even though I am not 100% certain in my conclusion, I would try disconnecting power and everything else for at least 10 minutes, ideally 30 minutes, and then check with only power connected. If it still blinks orange, I would conclude that it is defective beyond repair.
  • smb_corp_user
    In case my assumption is wrong, I would have tried the more advanced reset method of 30-30-30 (pushing the reset button for 30 seconds, release it for 30 seconds, press it for another 30 seconds). Please note that this method may work on some devices, but not all of them.
  • Zyxel_Bella
    Zyxel_Bella Posts: 560  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Administrator - Switch 50 Answers
    Hi @joudeh1996
    Steady orange LED means the NWA5123-AC failed to boot up or is experience system failure.
    As @smb_corp_user suggested, please reset AP by pressing hardware reset button for more than 20 seconds until LED begins to blink then release the button and wait for AP to restart.
    If you had download backup config file before, you can reload it to return the configurations after AP boot up.
    Thank you
    Regards,
    Bella
