Port Forwarding on USG210
2»
  • Derrick
    Derrick Posts: 16 image  Freshman Member
    This is what I have, but it still drops it. he he. I dunno what I am doing wrong?
    Is the silent alarm IP in the same subnet as LAN1?
  • Derrick
    Ok, so I have sorted it out. Selecting WAN interface on the NAT does not allow it. but selecting WAN_PPP, and it works.
    thanks to everyone that contributed to my thread your help and efforts are greatly appreciated!.
  • PetrJ
    PetrJ Posts: 1 image  Freshman Member
    First Comment Sixth Anniversary
    edited September 2018
    I have same problem on USG60W.
    Scenario ZLD Series Port Forwarding CR.pdf is clear, but forwarding still not working. Forwarded (NAT) as
    - port to port, or
    - service to service.
    - Is the service accessible locally? YES
    - Verify that the port(s) you are attempting to forward are correct? YES
    - Disable the ZyXEL device firewall/policy control. STILL NOT WORKING
    - If you running the services on a Windows MAC LInux ...  LISTENING
    - Disable the firewall on the computer/device that is running the service(s) to make sure it is not blocking the traffic. DISABLED
    Everything worked fine via old "dead" CISCO router. There was changed gateway from *.254 to *.1 only.
    Petr
    EDIT: Solved without modification of rules. Provider has assigned static IP to WAN1 from different range via DHCP, instead of dynamic IP. It took time.
