how to configure PXE on Zyxel Switch (xs3800-28)?
Dashmir
Dashmir Posts: 1 image  Freshman Member
Fourth Anniversary
edited August 2022 in Switch
Dear Zyxel and Community
The only DHCP option is the one with profile 82 that can be configured on the switch.
Is there a way to set up more DHCP options?
Possibly via CLI commands?
Is it possible to configure the DHCP option "PXE" on the XS3800-28?
best regards
  • mMontana
    mMontana Posts: 1,468 image  Guru Member
    Sorry for the dumb question: why use a switch as DHCP Server?
  • Zyxel_Chris
    Zyxel_Chris Posts: 739 image  Zyxel Employee
    Zyxel Certified Network Administrator - WLAN Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 50 Answers
    @Dashmir,
    Our switch does not support PXE, since it needs the specific column on DHCP however, our USG series can support this scenario, will recommend using it.  :)
