how to configure PXE on Zyxel Switch (xs3800-28)?
Dear Zyxel and Community
The only DHCP option is the one with profile 82 that can be configured on the switch.
Is there a way to set up more DHCP options?
Possibly via CLI commands?
Is it possible to configure the DHCP option "PXE" on the XS3800-28?
best regards
best regards
Sorry for the dumb question: why use a switch as DHCP Server?
@Dashmir,
Our switch does not support PXE, since it needs the specific column on DHCP however, our USG series can support this scenario, will recommend using it.
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
