XS1930-12HP Web Admin barely has anything and does not match manual
Why is that? How do I get access to configure everything? It isn't here in the Web Administration. Barely anything here. Just basic stuff.
User Guide: https://download.zyxel.com/XS1930-12HP/user_guide/XS1930-12HP_V4.70_Ed2.pdf
Handbook: https://download.zyxel.com/XS1930-12HP/handbook/XS1930-12HP_2020.1.pdf
Hi @random_pawn00,
Welcome to Zyxel community!
Once Nebula has controlled the switch, you would be unable to configure your switch via switch web GUI and it only shows little information.
Please configure/monitor your switch via Nebula control center.
If you need the Nebula switch user guide, please go to Menu > Help > switch to check.
Zyxel Melen0 -
Nebula does not allow all of the configuration listed in the manual... What is going on with that?
Unable to configure or use ipv6. Unable to configure any routes (it appears this is locked behind a Nebula fee). Unable to configure LLDP settings. Unable to change Web Admin timeout setting (neither in Web Admin NOR Nebula, so this is locked out 100%).
I don't understand why switch configurations available in Web Admin are missing in Nebula. Internet searches have turned up missing functionality with Nebula going back several years, which means they have not been addressed yet.
Nebula disables stuff and charges you to access it:
Hi @random_pawn00,Nebula Cloud Management provides users an easy configuration and management to switch.
Some of functions, such as IPv6, LLDP setting that lists in Standalone User Guide, are not provided on Nebula Control Center.
And some of functions, such as IP & Routing, ONVIF Discovery on Nebula, are Pro pack features which require Pro organization to use.
In addition, the Web Admin timeout setting could not be changed on Nebula Control Center is because user can monitor on Nebula Control Center and no need to access switch Web GUI.
Since most of the functions you list are not provided on Nebula Control Center, I suggest you could change to standalone mode to achieve your requirement.
Here are the steps to remove your switch from Nebula:Please go to Organization-wide > Configure > License & Inventory > Device tab, to select the switch you want to remove from the organization and click the action button, then click remove from the organization.
Zyxel Melen0 -
@Zyxel_Melen it's quite uninteresting tradeoff....
Remote/cloud management vs functionality disable? I mean... with a proper VPN and ACL setup you can quite have both of the worlds...1 -
Or how we are unable to configure inter-VLAN routing in Nebula
Hi @random_pawn00,
To configure inter-VLAN routing on Nebula, you can create VLAN IP interface on IP & routing page if your organization is Pro.
In addition, you have mentioned IPv6 & LLDP settings are unable to configure on Nebula Control Center.
Can you share more detail with us?
-What IPv6 settings do you want to use? Is it IPv6 interface or other configuration?
-What LLDP settings do you want to use? Is it LLDP MED or other configuration?
Is there any configuration you also need to set on Nebula? Please share with us.
Furthermore, if you are urgent to use these functions, we suggest changing your switch from Nebula management mode to standalone mode because the feature of standalone mode is more comprehensive.Zyxel Melen0 -
Sorry, but Zyxel is expecting us to pay to do something that is part of the Web based administration. Unacceptable. This is not some cheap switch.
Everything listed in the spec sheet and documentation needs to be in Nebula:
[ https://www.zyxel.com/dk/da/products_services/10-12-port-Multi-Gigabit-Smart-Managed-Switch-XS1930-Series/features ]
[ https://www.zyxel.com/dk/da/products_services/10-12-port-Multi-Gigabit-Smart-Managed-Switch-XS1930-Series/downloads ]
[ https://www.zyxel.com/dk/da/support/download_library/product/xs1930_series_25.shtml?c=dk&l=da&pid=20181219164921&tab=User_s_Guide&pname=XS1930 Series&mtname=User's Guide ]0 -
Following...0 -
Hi @random_pawn00,
First of all, thank you for your interest of trying out the XS1930 series for your network. Let me spend couple minutes to bridge the gap to see if it helps clarify your doubts.
Zyxel NebulaFlex Switches offers the flexibility to choose either cloud or on-premises standalone operation.
While there are still large group of users who prefers on-premises network management with all the handy features, we do see growing trend for adoption of cloud management.
The greatest benefit Nebula possess is the ability to perform centralized remote management, especially for handling multiple site operation. Nebula’s real-time status and mobile APP adds much more flexibility to managing your network even for single device. These are tools on-premises management system cannot offer. Our design for zero-tough deployment via QR-code and offering of 7-days historical data on Cloud just makes life much easier for network installation and management.
On the other hand, features supported on Nebula today are indeed baseline features due to the believe for importance of simplified configuration for Cloud Management. We have also seen similar believe across the board for many SMB cloud solution. Having said that, Zyxel continues to add valuable features through regular Nebula update every year. We are more than happy to accept idea of feature request to help advance our platform so feel free to send us your thoughts to help us improve our Nebula system.
We prepare documentation to better help users learn and select which platform suits their purpose, using footnote indication in datasheet and spec-sheet to identify specific features that are offer on Cloud. The User Guide for Cloud and Standalone management are specifically made into separate document as well. However, I do apologize if going through the above still leads to confusions. Let me take some time to enhance our collateral documentation so it can better welcome new Cloud users on board.
Hope it helps~
Best Regards,
Amy
Product Line Manager0
- 439 Beta Program
- 2.8K Nebula
- 207 Nebula Ideas
- 526 USG FLEX H Series
- 330 Security Ideas
- 49 Wireless Ideas
- 290 Service & License
- 4.5K FAQ
