Issue with VPN Connecting to Internal Devices from WAN Failover to LAN1
Match default rule, DNAT Packet, DROP [count=2] - 166.x.x.x 192.x.x.x - Access Block
I am doing this from a client device and the Source is the client device IP and the destination is the IP address of the device I want to access. Is there a special setting in the Policy Route that I need to enable to make sure that the VPN can see my internal devices connecting from the client device over the Wan Failover to the Lan1? I hope this helps. If you have idea I would love to get this working ASAP. Thank you.
So I fixed it. It turns out under "VPN Connection". The checkbox next to "Use Policy Route to control dynamic IPSec rules" was checked. I unchecked it and everything started working as usual. That was causing all the traffic to be blocked. Thank you for help and sorry for the confusion.0
Sounds like you have many issues...so if WAN2 is not connected does everything work? I'm guessing not? So you look to need a firewall rule to allow from WAN to LAN1
DNAT Packet is for a NAT Virtual Server that has nothing to do with a VPN
You say “Before I added that I was able to establish a successful VPN connection and access all my devices on LAN1 over WAN1” so if you disconnect WAN2 does it work?
Saying it worked before maybe it stopped working before you added the WAN2 and then think it was that I don't see how adding WAN2 break the VPN setup with WAN1 so I just want to make sure that adding WAN2 is the real reason its not working only for you to find out without WAN2 it doesn't work.
What VPN setup are you using on the Zywall Site-to-site or Remote Access (Server Role)? is the client using windows default VPN or ZyWALL SecuExtender?0
PeterUK said:What VPN setup are you using on the Zywall Site-to-site or Remote Access (Server Role)? is the client using windows default VPN or ZyWALL SecuExtender?0
So that will be L2TP over IPSec? Can you check the setting in the made VPN for windows has “use default gateway on remote network” checked.
Control Panel\Network and Internet\Network Connections
Normally you just need a Policy Control rule from like from IPSec_VPN to LAN10
- 434 Beta Program
- 174 Nebula Ideas
- 418 USG FLEX H Series
- 297 Security Ideas
- 43 Wireless Ideas
- 270 Service & License
- 416 News and Release
- 87 Security Advisories
- 4.1K FAQ
- 87 Security Highlight
