Issue with VPN Connecting to Internal Devices from WAN Failover to LAN1
PeterUK said:
So that will be L2TP over IPSec? Can you check the setting in the made VPN for windows has “use default gateway on remote network” checked.
Control Panel\Network and Internet\Network Connections
Yes client can connect fine but if the option is not checked then it will not work.
Also check a zone is set for the VPN on zywall
dcgtechnologies said:The error in logs is below:
Match default rule, DNAT Packet, DROP [count=2] - 166.x.x.x 192.x.x.x - Access Block0 -
Another thing is if you enable for routing"Use IPv4 Policy Route to Overwrite Direct Route"0
PeterUK said:dcgtechnologies said:The error in logs is below:
So I fixed it. It turns out under "VPN Connection". The checkbox next to "Use Policy Route to control dynamic IPSec rules" was checked. I unchecked it and everything started working as usual. That was causing all the traffic to be blocked. Thank you for help and sorry for the confusion.0
dcgtechnologies said:What are the parameters for the zone that needs to be set? Thank you.
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
