NAS326 new firmware V5.21 (AAZF.11)C0 - UPnP
geert
Since I have installed the new firmware V5.21 (AAZF.11)C0 the NAS326 is unable to find any UPnP supported routers. (router UpnP is active). I know that it is possible via port mapping (router) but sometimes I need myzyxelcloud to update UPnP on a remote nas/router. Any idea?
The new firmware on the release note do not mention there is behavior changing on the NAS itself
https://www.zyxel.com/support/download_landing/product/nas326_14.shtml?c=gb&l=en&pid=20150327120001&tab=Firmware&pname=NAS326#
I'm using NBG6615 as router above the NA326, it is still available to find the UPNP router.
Maybe try to reboot the router,NAS and check it again?0
Maybe try to reboot the router,NAS and check it again?0 -
Thx ikubuf,after rebooting the router and disable the switch setting "Unknown Multicast Drop" UPnP is working again!
You are right. Got the same results.geert said:Thx ikubuf,after rebooting the router and disable the switch setting "Unknown Multicast Drop" UPnP is working again!
- 240 Nebula Ideas
- 6.8K Security
- 755 USG FLEX H Series
- 379 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 320 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
